06-06-2003 06:14 AM - edited 03-02-2019 07:56 AM
We have the new WSX-4148RJ(v3.1) module on our Cat4506 and we are using straight UTP cables link to CSS11150(v5.0). This works fine.
However, when we switched to a older WSX-4148RJ (v2.3), it doesn't work unless we use cross cables.
Looking at the CSS installation guide, it does say we must use cross-cable for CSS<->switch link. I'm curious as to the new feature in the new WSX-4148RJ(v3.1) card that allows link even on straight cable.
Does anyone have the documentation on this feature? I've been searching high and low on CCO but can't find it. Thanks!
06-06-2003 06:24 AM
This correct, Cisco are incorporating a feature called "Auto MDI " in some of their later rev linecards which will allow the ports to determine whether you have a X-over or straight through cable attached.
For your linecard it first appeared on version 3.0
06-06-2003 07:12 AM
thanks for your reply. Yes, that's the feature. Do you know where I could find the document for this? I need to justify getting all new cards as we don't have factory made cross-cables over here. I don't suppose we could software upgrade the old WSX-4148RJ to support "Auto MDI" ?
Many thanks.
