Cisco 1601R serial port problem !!
derricktan
currently i have 2 units of Cisco 1601R router, both router are reporting the same problem. The problem of the router was the serial ports have no connection. Suspecting the serial ports got problem.
My question is, are there any ways to justify whether the serial port is faulty or not (if i don't have a lease line to test this routers) ????
ssoberlik
Level 4
Level 4
Fairly unlikely you have two Cisco routers with intermittent serial port problems. Have you checked with your SP during the outage to see if their line is down?
