cisco 2950-24 switch management problem
horvaia
I have problem while i want to reach my switch from
the internet. The problem is from the switch
I'm not able to ping even the default-gw too. It
seems none of the packets go out from the switch
itself. Very strange.
Switch IOS: c2950-i6q4l2-mz.121-20.EA1a.bin
Router IOS: c2600-is-mz.122-23a.bin
Does anybody have any idea?
Here are the configs:
router (2610):
interface Ethernet0/0
description uplink to switch [sw 0/1]
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
full-duplex
interface Ethernet0/0.100
encapsulation dot1Q 100
ip address 192.168.4.165 255.255.255.252
no cdp enable
interface Ethernet0/0.200
encapsulation dot1Q 200
ip address 192.168.11.81 255.255.255.240
no cdp enable
interface Ethernet0/0.450
description switch management
encapsulation dot1Q 450
ip address 192.168.4.169 255.255.255.252
no cdp enable
switch (2950-24):
ip subnet-zero
ip name-server 213.134.0.9
ip name-server 213.134.0.10
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
description trunk > switch
switchport mode trunk
speed 10
duplex full
interface FastEthernet0/2
switchport access vlan 100
interface FastEthernet0/3
switchport access vlan 200
interface Vlan450
ip address 192.168.4.170 255.255.255.252
no ip unreachables
no ip route-cache
ip default-gateway 192.168.4.169
no ip http server
Andras
You need to add the VLAN450 to the vlan database in order for it to become active. Even though you have the "interface vlan 450" defined, it will not function until the actual vlan is defined. Try adding VLAN450 and that will most likely solve your problems.
sstudsdahl
Level 4
Level 4
Try adding the native keyword to your encapsulation for vlan 450. It should look like:
encapsulation dot1Q 450 native
no cdp enable
Also, on your trunk port on the 2950, add the command:
"switchport trunk native vlan 450"
This will change the native VLAN from VLAN 1 to VLAN 450 for all frames that are not tagged with a dot1q ID.
Thanks for your idea. I tried it but it did not
work. I experienced the same problem. I'm able
to ping the router ip from the router and i'm able
to ping the switch vlan450 ip from the switch itself. But when I try to reach the switch from the
router it doesn't work. There isn't any ACL on the
interfaces. I just simply see an incomplete arp entry in the router arp table
(and of course in the switch arp table regarding the router ip). And there
is an another strange thing. Because there is the interface vlan450 in the switch but
when i issue the show vlan
command i can't see it. what is the problem?
see the outputs:
Thanks !!!
It has solved the problem!
