Cisco 4351 ISR Cable testing
anofzinger
Hello all,
I have a hopefully quick question.  I have recently begun to use the Cisco 4351 ISR in our networking setup.  I am looking for a method or process to test the ASync break out cables from the NIM module to the DB-25.  Our current process is to replace all 8 cables if one is suspected of failing.  Is there something builtin to the switch to test cables? Do you have any suggestions or recommendations?
0 Replies 0
