cisco 678 port forwarding problem
colbyd1
I have a cisco 678 and when I open a port set nat entry add 10.0.0.2 xxxx tcp, my connections (whether gaming or p2p) fail after a few minutes. I have a static ip. I have updated al nic drivers and all firewalls are disabled.
any suggestions?
vkapoor5
Level 5
Level 5
See if you are using the correct syntax as in http://www.cisco.com/univercd/cc/td/doc/product/dsl_prod/c600s/600inop/rconfig.htm .
You could probably check if the NAT translation entry is still available. Static entries should never timeout and should remain in the table
