11-22-2004 09:53 AM - edited 03-02-2019 08:08 PM
I have a Cisco 6905 with 10/100/1000 blades that are connected to some large database servers. About once a month I need to reboot this device because of very slow network responce time. Is there anything I can check on this device to see what could be causing this? Maybe a new IOS? Below is the show ver details.
c6509#show ver
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(17a)SX1, EARLY D
LOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 29-Oct-03 07:46 by cmong
Image text-base: 0x40008FBC, data-base: 0x41E50000
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(17a)SX1, EARLY D
c6509 uptime is 3 days, 30 minutes
Time since c6509 switched to active is 3 days, 30 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 12:18:56 EST Fri Nov 19 2004
System image file is "sup-bootflash:s72033-pk9sv-mz.122-17a.SX1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C6509 (R7000) processor (revision 3.0) with 458752K/65536K bytes of m
ory.
Processor board ID SAL0739M2JD
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
15 Virtual Ethernet/IEEE 802.3 interface(s)
148 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 458752K/65536K bytes of memory.
11-29-2004 07:08 AM
Check the Duplex settings, Cisco support full-duplex, the IEEE 802.3z standard does have support for half-duplex Gigabit Ethernet. Because of this, duplex is negotiating between Gigabit Ethernet devices.
In the Flow Control mechanism also gives slowness - Because of the amount of traffic that could be generated by Gigabit Ethernet, there is a PAUSE functionality built into Gigabit Ethernet. The PAUSE frame is a packet that tells the far-end device to stop transmitting packets until the sender is able to handle all the traffic and clear it's buffers. The PAUSE frame has a timer included which tells the far-end device when to start sending packets again. If that timer expires without getting another PAUSE frame, the far-end device can then send packets again.
You can try to disable the autonegotiation option on BOTH the switch and the NIC card of the server, and see if that improves communications.
For more troubleshooting in NIC Compatibility Issues, checks this below provide more related information.
