Cisco 7606 Power Supply Warning
Daniel Vieceli
Hello i have one Cisco 7606 and i'm seeing these errors messages like this:
338256: Mar 23 07:17:06.685 BRT: %C7600_PWR-SP-4-INPUTCHANGE: Power supply 2 input has changed. Power capacity adjusted to 1319.22W
338257: Mar 23 07:17:06.685 BRT: %C7600_PWR-SP-4-PSOUTPUTDROP: Power supply 2 output has dropped
338258: Mar 23 07:17:06.685 BRT: %C7600_PWR-SP-4-PSREDUNDANTMISMATCH: power supplies rated outputs do not match.
338259: Mar 23 07:17:06.685 BRT: %C7600_PWR-SP-4-PSNOREDUNDANCY: Power supplies are not in full redundancy, power usage exceeds lower capacity supply
338260: Mar 23 07:17:08.689 BRT: %C7600_PWR-SP-4-INPUTCHANGE: Power supply 2 input has changed. Power capacity adjusted to 2669.10W
338261: Mar 23 07:17:08.689 BRT: %C7600_PWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
system power redundancy mode = redundant
system power total = 2669.10 Watts (63.55 Amps @ 42V)
system power used = 1683.36 Watts (40.08 Amps @ 42V)
system power available = 985.74 Watts (23.47 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 PWR-2700-DC 2669.10 63.55 OK OK on
2 PWR-2700-AC 2669.10 63.55 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 FAN-MOD-6SHS 309.12 7.36 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 76-ES+XC-20G3C 309.12 7.36 309.12 7.36 on on
3 76-ES+XC-20G3C 309.12 7.36 309.12 7.36 on on
5 RSP720-3CXL-10GE 378.00 9.00 378.00 9.00 on on
6 (Redundant Sup) - - 378.00 9.00 - -
I'm searching but i doesn't discovered what happens.
Mark Malone
Hey
Your using AC and DC power supplies ? should be one or the other
