Cisco Switch 6500 Cabinet
Aholmes40
I have a 6509 cabinet with two 48port POe switches modules in it. My issue is when the power goes out in the building and the cabinet restarts , the modules have to be powered up manually after the cabinet/sup comes up. Is there a cli to autostart these badboys.. ? thanks so much
Andrew
9 Replies 9
Philip D'Ath
That doesn't sound right.  Are you running modern software on it?
Leo Laohoo
I'm keen to know what the logs say too.
leo sorry, I'm newbie . I used the sho logging command for this output
0:01:15: % Error opening nvram:/ifIndex-table No such file or directory
00:01:17: curr is 0x0
00:01:17: RP: Currently running ROMMON from S (Gold) region
00:01:21: %PARSER-4-BADCFG: Unexpected end of configuration file.
00:01:35: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
00:01:35: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
00:01:54: %SYS-5-RESTART: System restarted --
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(33)SXH8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 29-Sep-10 01:02 by prod_rel_team
00:00:04: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:01:14: SP: SP: Currently running ROMMON from S (Gold) region
00:01:20: %C6K_PLATFORM-SP-4-CONFREG_BREAK_ENABLED: The default factory setting for config register is 0x2102.It is advisable to retain 1 in 0x2102 as it prevents returning to ROMMON when break is issued.
00:01:53: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:01:53: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
00:01:53: %OIR-SP-6-INSPS: Power supply inserted in slot 2
00:01:53: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
00:01:53: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
00:01:53: %SYS-SP-5-RESTART: System restarted --
Cisco IOS Software, s72033_sp Software (s72033_sp-IPSERVICESK9-M), Version 12.2(33)SXH8, RELEASE SOFTWARE (fc1)
Compiled Wed 29-Sep-10 01:06 by prod_rel_team
00:01:55: %C6KENV-SP-4-FANHIOUTPUT: Version 2 high-output fan-tray is in effect
00:02:00: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 6 became active.
00:02:02: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
00:02:09: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
00:02:10: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
00:02:10: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
00:02:13: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
00:02:14: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
00:02:16: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics...
00:02:16: %DIAG-SP-6-RUN_MINIMUM: Module 5: Running Minimal Diagnostics...
00:02:26: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
00:02:26: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
00:02:37: %DIAG-SP-6-DIAG_OK: Module 5: Passed Online Diagnostics
00:02:37: %OIR-SP-6-INSCARD: Card inserted in slot 5, interfaces are now online
00:05:32: %PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 4 is experiencing the following error: Bus Asic #1 out of sync error
00:06:21: %SPANTREE-SP-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk GigabitEthernet3/5 VLAN1.
00:06:21: %SPANTREE-SP-7-BLOCK_PORT_TYPE: Blocking GigabitEthernet3/5 on VLAN0001. Inconsistent port type.
00:06:37: %SPANTREE-SP-2-UNBLOCK_CONSIST_PORT: Unblocking GigabitEthernet3/5 on VLAN0001. Port consistency restored.
00:07:15: %SYS-5-CONFIG_I: Configured from console by console
00:08:47: %SYS-5-CONFIG_I: Configured from console by console
00:10:32: %SYS-5-CONFIG_I: Configured from console by console
00:22:16: %SYS-5-CONFIG_I: Configured from console by console
01:16:36: %C6K_POWER-SP-6-NOLPP: Because of lack of system power, devices that require the system to power them on may not come up within one second.
22:38:15: %SYS-5-CONFIG_I: Configured from console by console
22:38:46: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet5/21 (not half duplex), with vpn-rt FastEthernet0/1 (half duplex).
22:38:47: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet5/21 (not half duplex), with vpn-rt FastEthernet0/1 (half duplex).
22:42:26: %SYS-5-CONFIG_I: Configured from console by console
1d22h: %SYS-5-CONFIG_I: Configured from console by console
1w6d: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet4/23 (not half duplex), with vpn-rt FastEthernet0/1 (half duplex).
2w4d: %SYS-5-CONFIG_I: Configured from console by console
2w4d: %SYS-5-CONFIG_I: Configured from console by vty0 (10.100.100.56)
2w4d: Configuring snmpv3 USM user, persisting snmpEngineBoots. Please Wait...
I am suspecting this is CSCsk16974.  The Cisco Bug ID identifies the Known Affected Release as 12.2(18)SXF17 but I'm suspecting the IOS version you're running is also included but the page wasn't updated accordingly.
thanks for the response. I will check this out and update the thread! appreciate it.
Hello
Can you also post:
sh power
sh power status all
sh module
res
Paul
Kind Regards
Paul
Thanks for helping out.. Here is Sho Power
system power redundancy mode = redundant
system power total =     1153.32 Watts (27.46 Amps @ 42V)
system power used =      1092.00 Watts (26.00 Amps @ 42V)
system power available =   61.32 Watts ( 1.46 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-2500W       1153.32 27.46  OK     OK     on
2    WS-CAC-2500W       1153.32 27.46  OK     OK     on
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
3    WS-X6408-GBIC        84.00  2.00    84.00  2.00  on    on
4    WS-X6148-GE-45AF    111.30  2.65   111.30  2.65  on    on
5    WS-X6148-GE-45AF    315.00  7.50   315.00  7.50  on    on
6    WS-SUP720-BASE      315.00  7.50   315.00  7.50  on    on
                        Inline         Inline         Inline         Inline
                        Pwr-Requested  Pwr-Allocated  Local-Pwr-Pool Power
Slot Card-Type          Watts   A @42V Watts   A @42V Watts   A @42V Status
4    WS-F6K-GE48-AF       15.54  0.37   138.42  3.30     -     -     On
5    WS-F6K-GE48-AF        -     -      125.84  3.00     -     -     On
Here is Sho Power Status All
sho mod
Mod Ports Card Type                              Model              Serial No.
  3    8  8 port 1000mb ethernet                 WS-X6408-GBIC      SAD040908JX
  4   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-45AF   SAL1003AZXV
  5   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-45AF   SAL1002A2ST
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE     SAD07520856
Mod MAC addresses                       Hw    Fw           Sw           Status
  3  00d0.d39f.b0b4 to 00d0.d39f.b0bb   2.4   5.1(1)CSX    8.7(0.22)BUB Ok
  4  0016.c7b3.19e8 to 0016.c7b3.1a17   1.1   7.2(1)       8.7(0.22)BUB Ok
  5  0016.c748.7540 to 0016.c748.756f   1.1   7.2(1)       8.7(0.22)BUB Ok
  6  000e.3838.1f3c to 000e.3838.1f3f   3.0   7.7(1)       12.2(33)SXH8 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  4  IEEE Voice Daughter Card    WS-F6K-GE48-AF     SAL09528VXE  1.2    Ok
  5  IEEE Voice Daughter Card    WS-F6K-GE48-AF     SAL1002A367  1.2    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3A       SAD075300BM  2.0    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAD075206LZ  2.0    Ok
Mod  Online Diag Status
  3  Pass
  4  Pass
  5  Pass
  6  Pass
