CISCO WS-C3750E-48PD-SF Power outage is only showing Syst LED
bkepley93
We had just had a brief power outage. When the power came back on the switch would power up the switch would not show any other LEDs and would not do its normal port test and normal post-test. When powering up it would only blink syst LED and then the syst LED would stay steady. The fan does come on and power it does show that it has power. when connecting to the computer using the console cable the console port doesn't even respond. The switch only shows Syst LED but doesnt show anything connected or anything. It doesnt even do its normal startup
marce1000
 - Hoping you have a saved configuration, according to my opinion your options are limited to a factory defaults reset, If it remains unresponsive (console) and it got killed somehow by the outage,
 M.
marce1000
 M.
I was attempting to open the case of the switch to see if something like a capacitor blew up but when trying to take off the one rack-mount I noticed the heads of the two screws were badly stripped. is there any way to take off the cover as I am unable to remove the rack-mount ear
Leo Laohoo
Console into the switch and reboot.
Post the entire boot-up process.
