Connecting Cisco Router to System
usmany
Guys,
I need assistance on how I will connect my cisco router 3640 to a system not to switch/hub for troubleshooting through Ethernet port not console nor auxiliary port...
I just want to know if is possible to connect straight from the ethernet port of the router to system NIC and how will I make the cabling?
I tried straight and cross over cabling, but did even blink... I am sure there is a way in making the cabling work.
Cisco gurus should please intervain/advice on this issue
krozier
Hi USMANY,
It is quite possible to connect a router to P.C's, that is the best way to download IOS to the router. To connect 3640's (or any cisco router for that matter) ethernet interface to a P.C. that would require cross-over cable. After connecting the cross-over cable to the router and the P.C.you do not get a link link, you need to make sure that the ethernet port on the router is enabled and check the cabling. Let me know if you need additional pointers.
Kersean
thanks, i will try it now and i will brief you on any development.
Both interfaces (router & pc) should use the same IP network.
okay guys, i will do that as advice and get back to you too.
thanks all for the help
