Content Switch Module
Ahmede
We have 2 6513 switches, we will added SSL module and CSM module in each switch. Right now the two CSM is in Active/Standby mode.. Is there any way to make them in active/active mode? Do you have any configuration example..
ankurbhasin
Level 9
Level 9
HI Ahmed,
I do not think both can be active as to configure fault taolerent the basic requirement is both the CSM shuld be identical with sam config and one should be active and second should be standby
Check this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/csm/csms211/icn/redun.htm#wp1037240
Still let some expert on CSM answer this.
Ankur
