CUBE SIP between an Avaya CS1000 and NEC 2400
spc_fisherja
I have been task to connect a CUBE between an NEC 2400 and an Avaya CS1000 using SIP trunking.  Has anyone done this before if so sample configs would be appricaited. Thanks
ajay1komban
Hii Spc_fisherja,
                              Please find attached file.You can Just go throug it.
Ajay Jose
Thanks for the reply but I am looking for a sample on this drawing.
NEC 2400 NEAX --  GW (?)--  CUBE -- CS1000 Avaya
Both system will connect to the CUBE via ethernet and using dial-peers to place calls
using sip/h323 from end to end as required.
