DB9 to RJ48c cable connection pinout
sgentili
Does anyone know how cabling must be between an RJ48c connector and a DB9 ones?
Since I had to connect one port of VWIC-2MFT-E1 (2 port RJ48c) to one DCE (AETRA SA11) having a DB9 (120 ohm) output.
Many Thanks
Secondo
scottmac
Level 10
Level 10
Are you sure about the DB9? Sometimes the T1 port of a CSU/DSU is a DB15 ... I havent seen a DB9 being used before (for a T1).
If it is a DB15:
The mapping is 1&2 on the RJ going to pins 1&9 (leftmost two pins, one above the other) and 4&5 going to pins 8&15 (the two rightmost pins, one above the other).
FWIW
Scott
