12-17-2003 06:45 AM - edited 03-02-2019 12:24 PM
Hi!
I have a problem with subj on Catalyst 5505 without
UPLINK module.
If connect computer with MAC 0060.08C8.498F and ip 1.8.7.214 to ports 2/24 èëè 3/24 then ...nothing
Console> (enable) sh vmps mac
MAC Address VLAN Name Last Requestor Port ID Last Accessed Last Response
00-60-08-c8-49-8f DV1 0.0.0.0 0,00:00:00 Success
Console> (enable)
Configs and other:
Console> (enable) sh ver
WS-C5505 Software, Version McpSW: 6.4(4) NmpSW: 6.4(4)
Copyright (c) 1995-2003 by Cisco Systems
NMP S/W compiled on Jun 3 2003, 23:48:21
MCP S/W compiled on Jun 03 2003, 23:43:25
System Bootstrap Version: 3.1.2
Hardware Version: 1.0 Model: WS-C5505 Serial #: 066536104
Mod Port Model Serial # Versions
1 0 WS-X5530 006807147 Hw : 1.5
Fw : 3.1.2
Fw1: 3.1(2)
Sw : 6.4(4)
WS-F5520 007617024 Hw : 1.0
2 24 WS-X5224 010094435 Hw : 1.4
Fw : 3.1(1)
Sw : 6.4(4)
3 24 WS-X5224 010921869 Hw : 1.4
Fw : 3.1(1)
Sw : 6.4(4)
4 24 WS-X5224 008170018 Hw : 1.3
Console> (enable)
onsole> (enable) sh config
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Fri Dec 5 2003, 10:45:35
#version 6.4(4)
set option fddi-user-pri enabled
set config mode text nvram
#frame distribution method
set port channel all distribution mac both
#vtp
set vtp domain TMP1
#ip
set interface sc0 2 1.8.7.221/255.255.255.240 1.8.7.223
set ip route 0.0.0.0/0.0.0.0 10.10.10.1
set ip alias default 0.0.0.0
#vmps
set vmps server 1.8.7.221 primary
set vmps downloadserver 1.8.7.211 vmps.db
set vmps state enable
# default port status is enable
#module 1 : 0-port Supervisor III
#module 2 : 24-port 10/100BaseTX Ethernet
set vlan 2 2/2-5,2/7-12
set vlan 3 2/6
set vlan 8 2/13
set vlan 9 2/14
set vlan 10 2/15
set vlan 11 2/16
set vlan 12 2/17
set vlan 14 2/18
set vlan 15 2/19
set vlan 20 2/20
set vlan 21 2/21
set vlan 22 2/22
set vlan 23 2/23
set port speed 2/24 100
set port duplex 2/24 full
set port membership 2/24 dynamic
set spantree portfast 2/24 enable
#module 3 : 24-port 10/100BaseTX Ethernet
set port membership 3/24 dynamic
set spantree portfast 3/24 enable
#module 4 : 24-port 10/100BaseTX Ethernet
#module 5 empty
end
Console> (enable)
vmps.db contents
!VMPS File Format, version 1.1
! Always begin the configuration file with
! the word "VMPS"
!vmps domain <domain-name>
! The VMPS domain must be defined.
!vmps mode {open | secure}
! The default mode is open.
!vmps fallback <vlan-name>
!vmps no-domain-req { allow | deny }
! The default value is allow.
vmps domain DV
vmps mode open
vmps fallback default
vmps no-domain-req deny
!MAC Addresses
vmps-mac-addrs
! address <addr> vlan-name <vlan_name>
address 0060.08C8.498F vlan-name DV1
!Port Groups
!vmps-port-group <group-name>
! device <device-id> { port <port-name> | all-ports }
vmps-port-group DV1pg
device 1.8.7.214 port 2/24
device 1.8.7.214 port 3/24
!VLAN groups
!vmps-vlan-group <group-name>
! vlan-name <vlan-name>
vmps-vlan-group DV1vg
vlan-name DV1
!VLAN port Policies
!vmps-port-policies {vlan-name <vlan_name> | vlan-group <group-name> }
! { port-group <group-name> | device <device-id> port <port-name> }
vmps-port-policies vlan-group DV1vg
port-group DV1pg
TFTP Server - Cisco Tftp Server - i see in log
following records:
Thu Dec 04 19:03:50 2003: Sending 'vmps.db' file to 1.8.7.221 in binary mode
Thu Dec 04 19:03:50 2003: Successful.
Then in 5505 console
Console> (enable) 2003 Dec 04 15:51:52 %VMPS-2-PARSEMSG:PARSER: 54 lines parsed, Errors 0
VMPS configuration file downloaded.
I think that DB is loaded but not work - WHY ?
Help me, plz
Evgen
12-17-2003 06:34 PM
Try removing all the port-group and port-policies stuff and see if it works then. The port-group appears to be wrong: the line "device 1.8.7.214 port 3/24" specifies the IP of the host when it should specify the IP of the switch. The switch is the device: the "device y port x" command tells VMPS to associate the port-group with port x on device (switch) y.
12-19-2003 01:13 AM
I try, but nothing....
! the word "VMPS"
!vmps domain
!vmps fallback
vmps domain DV
vmps mode open
vmps no-domain-req allow
!MAC Addresses
vmps-mac-addrs
! address
address 0060.08c8.498f vlan-name DV1
and try
! the word "VMPS"
!vmps domain
!vmps fallback
vmps domain DV
vmps mode open
!MAC Addresses
vmps-mac-addrs
! address
!Port Groups
!vmps-port-group
! device
device 1.8.7.221 port 2/24
device 1.8.7.221 port 3/24
!VLAN groups
!vmps-vlan-group
! vlan-name
vlan-name DV1
!VLAN port Policies
! { port-group
port-group DV1pg
nothing too....
Plz mail me functioning
config and vmps db
My mail kneg@mail.ru
Thank you!
12-19-2003 04:20 AM
Its ELEMENTary, My Dear Watson
VMPS domain name must be the same as the VTP domain of the network.
It working well now - thanks for all!
