enable http login to switch
reagentom
hi,
Is it possible to enable login by http (web interface) to catalyst 4006 switch with WS-C4006 Software, Version NmpSW: 6.3(5) ??
21 Replies 21
Thanks ankur,
Then now I think I have to copy only cat4000-cv.6-3-2a.bin image and it will work.. is it right ??
and what about my current config it will be still there or may be affected !!
Hi Ahmed,
yes you are right just copy the cv image and it will take care of the things and it will not affect the config as we are not changing the main system file and cv image is just for HTTP access and will not disturb the main config but always recommended to take the backup of your old config just for precaution.
Ankur
Hi Ahmed,
Did you tried? Howz the result?
Ankur
hi ankur,
it's already copied to flash and I have schaduled the restart at the end of the day.. I'll let u know about the result
Dear Ankur;
Thank you very much now it's working and I can access it.. I will try to find what's missing configuration and let u know
Pls check your mail ..
Great...Glad to know its working
Ankur
o4u2sweat1
Hello Guys I am new to this and I am looking for help. I have a 2980g  that I am working with. I am trying to get  6.3.2a or better so that I can get the http to work. I am also looking for a upgrade path if any. I am running what looks like 6.1.4. Please  if you can send me a link. I maybe able to help who ever I have many contacts to enterprise system products. But since my company and Cisco are not on good terms they limit our access.  Dougljb@comcast.net    Thanks in advance..
