Etherchannel in standalone mode due to not matching port numbers?
keesepema
A student posted a PacketTracer file in which he configured on switch1 port range  fa0/1-8 in portchannel 1 LACP. On the second switch he configured fa0/17-24 in portchannel 1 LACP.
If I issue
show eth summary
on both switches, it shows that the underlying switchports are not in (P) portchannel, but in standalone mode (I).
Should he have configured on both switches the same portnumbers? So on S1 fa0/1-8 and also on S2 fa0/1-8?
M02@rt37
Hello @keesepema,
Port numbers do not need to match on both ends. What matters is that the two switches agree on the logical port channel number and the LACP mode.
Best regards
 port number not effect portchannel status you can select any number but some cisco doc. Suggest use port from same slot (if SW have many slots)
MHM
I dont answer directly to find this issue
In real network see what happened when use multi slot (line card) for port channel
https://community.cisco.com/t5/switching/cisco-9000-port-channel-suspended-error-due-to-different-speed/td-p/4447630
M02@rt37
Hello @keesepema,
Best regards
