FTP problems still...
jmartina
ok..I posted this last week, and i still can not get it to work, everything else works...but can't get ftp to work...does any one have a config i can compare?
here is entire config
Current configuration : 3170 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname router1
logging buffered 16384 debugging
enable secret 5
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip tcp path-mtu-discovery
ip dhcp pool dhcppool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 7
no ip bootp server
ip audit attack action alarm reset
ip audit notify log
ip audit po max-events 100
ip cef
interface Ethernet0
ip address dhcp
ip access-group 100 in
ip access-group 101 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip nat outside
half-duplex
ntp disable
no cdp enable
interface FastEthernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
speed auto
no cdp enable
ip nat inside source list 1 interface Ethernet0 overload
ip nat inside source static tcp 10.10.10.60 13015 interface Ethernet0 13015
ip nat inside source static tcp 10.10.10.60 13014 interface Ethernet0 13014
ip nat inside source static tcp 10.10.10.60 13013 interface Ethernet0 13013
ip nat inside source static tcp 10.10.10.60 13012 interface Ethernet0 13012
ip nat inside source static tcp 10.10.10.60 13011 interface Ethernet0 13011
ip nat inside source static tcp 10.10.10.60 13010 interface Ethernet0 13010
ip nat inside source static tcp 10.10.10.60 21 interface Ethernet0 21
ip nat inside source static tcp 10.10.10.60 20 interface Ethernet0 20
ip classless
no ip http server
ip pim bidir-enable
ip access-list extended internet-in
logging 10.10.10.66
access-list 1 permit 10.0.0.0 0.255.255.255 log
access-list 100 permit tcp any any established log
access-list 100 permit tcp any gt 1023 host 10.10.10.60 eq ftp-data log
access-list 100 permit tcp any gt 1023 host 10.10.10.60 eq ftp log
access-list 100 permit tcp any gt 1023 host 10.10.10.60 eq 1023 log
access-list 100 permit icmp any any net-unreachable
access-list 100 permit icmp any any host-unreachable
access-list 100 permit icmp any any port-unreachable
access-list 100 permit icmp any any parameter-problem
access-list 100 permit icmp any any packet-too-big
access-list 100 permit icmp any any administratively-prohibited
access-list 100 permit icmp any any source-quench
access-list 100 permit icmp any any echo-reply
access-list 100 permit ip any any log
access-list 101 permit ip any any log
access-list 101 permit tcp any any log
access-list 101 permit udp any any log
no cdp run
banner motd ^C
* WARNING *
line con 0
line aux 0
line vty 0 3
password 7
login
telnet refuse-negotiations
line vty 4
password 7
login
Yes, it was me indeed. Just checking if everything was working fine. It is working now ;o)
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
19 Replies 19
Harold Ritter
A couple of things.
First, you should use the global address as part of the access-list not the local address (10.10.10.60). I know in your case the global address is the address dynamically assigned to FastEthernet0, so the easiest would be not to specify the address at all.
Secondly, you use the same inbound access-list (100) in both directions. Remember that the ACL is directional, meaning that source and destination will not be the same in the other direction. It is not a problem for now since you have an explicit permit any any at the end of the ACL but it might be later on.
Any reason why you need the apply an ACL on the internal interface (FastEthernet0) in the first place.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
i applied it to the fa0 int for trouble shooting, i thought maybe since i had it applied to e0 i would need them applied to the other int too, guess not?
when you say global address you mean network ip ? 10.10.10.0 or 0.0.0.0 ?
ok..i didnt read you post to closely the first time, here is the acl list now im running but its still not working, i do a port scan from sygate i have 21 open and 23 too, which i cannot figure out why its open i didnt say open 23....
access-list 100 permit tcp any gt 1023 any eq ftp-data log
access-list 100 permit tcp any gt 1023 any eq ftp log
access-list 100 permit tcp any gt 1023 any eq 1023 log
Port 23 is handle the local router as opposed to the server behind it.
Also bear in mind that the current list will not work for passive FTP from an external station to you internal FTP server. Try the same FTP to your internal server using regular FTP as opposed to passive FTP.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
If what you want to do is protecting you internal network from traffic coming from the Internet then only inbound ACL on Ethernet0 should do.
The global address is the address seen on the Internet when you NAT (in your case it is the address of the outside interface). The local address is the address known to your internal network (10.10.10.0).
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
ok...here it is is this right?
access-list 100 permit tcp any gt 1023 host 24.223.139.68 eq ftp-data log
access-list 100 permit tcp any gt 1023 host 24.223.139.68 eq ftp log
access-list 100 permit tcp any gt 1023 host 24.223.139.68 eq 1023 log
This should be ok but bear in mind that since you get this address dynamically via DHCP it will change. That is why I said that it would be easier not to specify any destination address.
Also, could you tell me what is the following for:
Did you mean to configure "gt 1023" for passive FTP?
Thx,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
yea i did actually i fixed it, hey here is my Nat translations maybe this will help....
Pro Inside global Inside local Outside local Outside global
udp 24.223.139.68:108 10.10.10.66:138 10.255.255.255:138 10.255.255.255:13
udp 24.223.139.68:137 10.10.10.60:137 10.255.255.255:137 10.255.255.255:13
udp 24.223.139.68:138 10.10.10.60:138 10.255.255.255:138 10.255.255.255:13
tcp 24.223.139.68:22411 10.10.10.60:22411 207.33.111.32:80 207.33.111.32:80
tcp 24.223.139.68:22416 10.10.10.60:22416 207.33.111.32:80 207.33.111.32:80
tcp 24.223.139.68:22417 10.10.10.60:22417 207.33.111.32:80 207.33.111.32:80
tcp 24.223.139.68:22412 10.10.10.60:22412 65.61.165.21:80 65.61.165.21:80
tcp 24.223.139.68:22413 10.10.10.60:22413 65.61.165.21:80 65.61.165.21:80
tcp 24.223.139.68:22414 10.10.10.60:22414 207.33.111.32:443 207.33.111.32:443
tcp 24.223.139.68:1166 10.10.10.66:1166 64.246.169.201:80 64.246.169.201:80
tcp 24.223.139.68:1167 10.10.10.66:1167 64.246.169.201:80 64.246.169.201:80
tcp 24.223.139.68:1316 10.10.10.66:1316 66.28.176.48:80 66.28.176.48:80
tcp 24.223.139.68:20 10.10.10.60:20 --- ---
tcp 24.223.139.68:21 10.10.10.60:21 --- ---
udp 24.223.139.68:1029 10.10.10.66:1029 207.69.188.185:53 207.69.188.185:53
tcp 24.223.139.68:20 10.10.10.60:20 207.33.111.37:43594 207.33.111.37:43
tcp 24.223.139.68:21 10.10.10.60:21 207.33.111.37:43594 207.33.111.37:43
tcp 24.223.139.68:1993 10.10.10.65:1993 207.46.106.149:1863 207.46.106.149:1
udp 24.223.139.68:137 10.10.10.60:137 192.168.0.10:137 192.168.0.10:137
tcp 24.223.139.68:22407 10.10.10.60:22407 216.239.41.104:80 216.239.41.104:80
tcp 24.223.139.68:22408 10.10.10.60:22408 216.239.41.104:80 216.239.41.104:80
tcp 24.223.139.68:22419 10.10.10.60:22419 216.239.41.104:80 216.239.41.104:80
tcp 24.223.139.68:20 10.10.10.60:20 207.33.111.35:44153 207.33.111.35:44
tcp 24.223.139.68:13010 10.10.10.60:13010 --- ---
tcp 24.223.139.68:21 10.10.10.60:21 207.33.111.35:44153 207.33.111.35:44
tcp 24.223.139.68:13011 10.10.10.60:13011 --- ---
tcp 24.223.139.68:13012 10.10.10.60:13012 --- ---
tcp 24.223.139.68:13013 10.10.10.60:13013 --- ---
tcp 24.223.139.68:13014 10.10.10.60:13014 --- ---
tcp 24.223.139.68:13015 10.10.10.60:13015 --- ---
tcp 24.223.139.68:4902 10.10.10.66:4902 81.0.254.167:80 81.0.254.167:80
tcp 24.223.139.68:4903 10.10.10.66:4903 81.0.254.167:80 81.0.254.167:80
tcp 24.223.139.68:22420 10.10.10.60:22420 216.45.19.33:80 216.45.19.33:80
tcp 24.223.139.68:22421 10.10.10.60:22421 216.45.19.33:80 216.45.19.33:80
tcp 24.223.139.68:22422 10.10.10.60:22422 216.45.19.33:80 216.45.19.33:80
tcp 24.223.139.68:22423 10.10.10.60:22423 216.45.19.33:80 216.45.19.33:80
Could you also please post the latest config including all the modifications.
Thx,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
no mmi pvc
ip subnet-zero
no ip source-route
import all
lease 7
no ip bootp server
ip audit notify log
ip cef
interface Ethernet0
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
half-duplex
ntp disable
no cdp enable
ip nat inside
speed auto
no cdp enable
ip classless
no ip http server
ip pim bidir-enable
logging 10.10.10.66
access-list 100 permit tcp any any range 13010 13015
access-list 100 permit tcp any any eq ftp
access-list 100 permit tcp any eq ftp-data any gt 1023
access-list 100 permit tcp any eq ftp any gt 1023
no cdp run
banner motd ^C
* WARNING *
line con 0
line aux 0
line vty 0 3
access-class 1 in
password 7
login
line vty 4
access-class 1 in
login
What is interesting is that we can't even ping your global address. Given your access-list we should at least be able to do that. Is it possible that some other router in the path is filtering?
Thx,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
hey i changed the last digits of the IP to .68 its really .66 sorry...thanks
Is the FTP server (10.10.10.60) up and running?
Thx,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
yea...i rebooted about 20 mins ago, was this u 12.159.148.x ?
