Hi, I have a 1921 and 1941 and am using EHWIC-4G-LTE-GB for LTE/3G.
I would like to get the GPS working but it only works very intermittently...
controller Cellular 0/1
lte sim data-profile 2 attach-profile 2
lte gps mode standalone
lte gps nmea
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
I have done lte gps enable and the relevant output for sh cell 0/1/0 gps detail is:
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS Status: GPS acquiring
GPS auto tracking status: active
GPS auto tracking config: enabled
GPS Mode Configured: standalone
Latitude: 0 Deg 0 Min 0 Sec North
Longitude: 0 Deg 0 Min 0 Sec East
Timestamp (GMT): Sun Jan 6 00:00:00 1980
Fix type index: 0
HDOP: , GPS Mode Used: not configured/unknown
Satellite Info
I have used an active (amplified) antenna and also a passive antenna but 95% of the time no fix is obtained and no satellites acquired.
What is particularly puzzling is that a couple of days ago, a fix was acquired and about 9 satellites detected!
Since then I have not changed anything but no fix has been obtained.
Weather has not been significantly different either.
I've setup GPS successfully on an Cisco C887VAG-4G-GA-K9 , which is essentially an EHWIC-4G in a box.
I have ALSO tried 3 different IOS versions - a T release and M releases. Quite recent ones - 15.6 15.7 and 15.8.
Any pointers would be much appreciated!
Cheers, Bill
PS ok, well, I have again rebooted again and of course, the GPS is working!
And it is heavy rain and overcast - worse weather than when I have previously tried, so that is not the solution.
Output of GPS now is:
sh cell 0/1/0 gps
GPS Info
GPS Status: GPS coordinates acquired
Last Location Fix Error: Not Available [0x0]
Latitude: 52 Deg 13 Min 48.1501 Sec North
Longitude: 0 Deg 5 Min 18.3852 Sec East
Timestamp (GMT): Sun Feb 18 09:52:06 2001
Fix type index: 0, Height: 55 m
Satellite Info
Satellite #1, elevation 83, azimuth 67, SNR 38 *
Satellite #3, elevation 54, azimuth 229, SNR 32 *
Satellite #8, elevation 19, azimuth 164, SNR 32 *
Satellite #11, elevation 52, azimuth 140, SNR 33 *
Satellite #17, elevation 26, azimuth 312, SNR 28 *
Satellite #21, elevation 31, azimuth 106, SNR 29 *
Satellite #22, elevation 79, azimuth 208, SNR 35 *
Satellite #28, elevation 23, azimuth 271, SNR 29 *
Satellite #32, elevation 30, azimuth 53, SNR 42 *
I will still make this post in case anyone has any pointers to the GPS feature being flakey!
Cheers again!
