Guide or instruction about build and config NAT for network.
eitt.world
Hey everybody. I’m having learn CCNA CISCO, I have a problem when I build a network, a network required that: Construct and build a topo network have 4 Router, 6 Switch, 8 PC, auto set and config IP address for communication between equipment in your topo network. Give some suggest : 3->4 IP front, 1 range 4 IP route, 2 range 8 IP route, 1 range 16 IP route. Les’t raise, give method and config NAT for it network with: Static NAT, Dynamic NAT, PAT and NAT co-ordinate.
Please give some guide or instruction me about that lab, Thank very much
5 Replies 5
eitt.world
who know? please help me ? I need some guide or opinion ?
Hello Mai,
Here are some tutorials how to configure NAT. Do you have problems with something particular?
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/260-cisco-router-nat-overload.html
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hey all here is a topo (model) network I do by myself and I have cofig NAT for it. Please see, check, fix error or guide me to fix error if it have error. Thank very much.
http://i1095.photobucket.com/albums/i472/OLAKEN91/gt_zpsa5f0f122.jpg
As a subject I have propose use a IP range is 200.200.5.1/27
b/Static NAT for IP PC8 192.16.6.1 to become IP 200.200.5.1 with a Network outside.
Router3(config)#ip nat inside source static 192.168.1.2 200.200.5.1
Router3(config)#interface fa 1/0
Router3(config-if)#ip nat inside
Router3(config-if)#interface s 0/0
Router3(config-if)#ip nat outside
a/ Accept PC in LAN 192.168.5.1/24 go out internet, this IP will be nat by IP range 200.200.5.1-> 200.200.5.6 (IP 200.200.5.1 have use for Static NAT but we can reuse).
Router3(config)#access-list 1 permit 192.168.5.0 0.0.0.255
Router3(config)#ip nat pool natdong 200.200.5.1 200.200.5.6 netmask 255.255.255.248
Router3(config)#ip nat inside source list 1 pool natdong
Router3(config)#interface fa 0/0
c/ Accept PC in 2 LAN 192.168.1.0/24 and 192.168.2.0/24 go out internet, this IP range will be NAT by IP range 200.200.5.33-> 200.200.5.48 (16 Ip address)
Router3(config)#access-list 1 permit 192.168.1.0 0.0.0.255
Router3(config)#access-list 1 permit 192.168.2.0 0.0.0.255
Router3(config)#ip nat pool natpat 200.200.5.33 200.200.5.48 netmask 255.255.255.224
Router3(config)#ip nat inside source list 1 interface serial 0/0 overload
Router3(config)#ip nat inside source list 1 pool natpat overload
[b]Note: My ability of English is not good so please sympathize for spelling mistake[/b]
who know ? plz see and fix it for me, I have do it above.
Hello Mai,
You did not mentioned what is working and what is not, it is hard to assume what could be wrong.
Also you have some typos in your post:
- you said that 192.168.6.1 will be NATed to 200.200.5.1, but you have configured "1.2"
- you should configure overload keyword here, it is PAT - port address translation
- I do not understand why did you configure two NAT rules, you need just one rule.
- this entire condif should be configured on Router 1 because "1" and "2" networks are terminated there.
Best Regards
