HELP !!! PPP with Predictor compress and CBWFQ
nceitil
I can't seem to to get CBWFQ to work with PPP Predictor compression.
I'm using a 1721 and 2620XM both running 12.3.5b IP base.
All traffic seems to only match the default queue. I'm getting compression ratios of 3-4 to 1 so I would like to keep it on.
However NO traffic seems to match the other queues. I've pushed the line to 99% without any success.
Anyone got any suggestions. I have attached the config of two routers. The network is a star topology. I have several sites hanging off the 2600. All of them are 1721 routers.
Nuno
olorunloba
Level 5
Level 5
Where is the traffic matching only the default class, at the remote or the head office.
Note that at the head office, I would have expected that the access-list would match the source tcp port and not the destination port, since the traffic direction is on the output.
At both ends it only matches the default class.
You right about the source / dest port. I will go ahead and change that. Still the last entry is the server that the traffic would either be going to or coming from. So I should still matches based on that entry alone.
Any ideas ???
