Help with Cisco 1720 (ISDN DDR Backup)
GByoung
Hello everyone.
I'm trying to configure a 1720 with a ISDN backup for the serial line.
I have int BRi0 set up like this
no ip address
no ip directed-broadcast
encapsulation ppp
dialer rotary-group 0
isdn switch-type basic-5ess
no fair-queue
no cdp enable
and int Dialer0 like this
ip address negotiated <---- Dialup ISDN using DHCP on ISP side
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 300
dialer string 7774660
dialer hold-queue 10
dialer load-threshold 200 outbound
dialer-group 1
no fair-queue
no cdp enable
Lastly my route commands and access-lists
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Dialer0 250
no ip http server
access-list 101 permit ip any any
access-list 101 permit icmp any any
dialer-list 1 protocol ip permit
All the above works very well. When I take int serial0 off-line, int Dialer0 kicks in and connects via int BRI0.
However no outgoing packets are being routed from the interface connected to the LAN. I can get out from the router, but not from the internal network.
Any help would be appreicated
Greg
lgijssel
Level 9
Level 9
You have a static route with metric 1 configured for serial 0. This will always be preferred over the backup route with a distance of 250.
To get round this issue you can use the command: backup interface dialer0 on s0 but this will only work when the interface goes physically down.
The other (preferrable) solution is that you use a routing protocol to advertise the route over int s0 and a floating static (higher distance than the routing protocol) on the dialer.
GByoung
Thanks for the sugesstion, but I already have int Dialer0 configured as a backup for int Serial0 interface Serial0 description 768K line to Frontier_AZ backup delay 10 30 backup interface Dialer0 Our provider will not allow us to configure the routers with RIP or such. The reason for the ISDN line is just that. To kick in when the Serial Interface goes physically down.
Greg
