Help with Netconfig
bw3481
I am trying to use netconfig to update my running-config on a 2620 router. I would like to call the file from tftp server. If I enter the command below into the router, it will copy my changes int the router, but I must hit return once after the file was entered to verify where to write the file.
copy tftp://1.1.1.1/tftpboot/configfile run
When I create a template in netconfig and put in the same command as above, I recieve the following error message:
Update Result: Failed
FAILURE
-CLI OUTPUT-
FAILURE
Any ideas on how the get ciscoworks to call the file from my tftp server ??
Thanks in advance.
Ben
amritpatek
Level 6
Level 6
Did you check the connectivity to the tftp server? If it is fine, did you double check the filename of the configuration file? If both of these are fine, then I guess, you should be missing some of the NetConfig Requirements given in the document below:
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_tech_note09186a00800a6974.shtml#requirements
Or may be, you could use the Config Editor for this purpose.
