How do I set credentials for C829FSP web interface
zbryant
I want to use Cisco Configuration Professional Express to access my C829FSP, but it wants credentials.
I set it up with the http server (not the secure server).
What credentials do I need to set using CLI, in order to access this web portal. I accessed it before, but had to clear the router configuration and start over. But now the cisco/cisco combination doesn't work or several iterations around that. username1/password1 doesn't work either.
I thought username <username> privilege 15 secret 0 <password> was what I needed, but that didn't seem to work either.
the local username and password should work. Do you have:
Router(config)# ip http authentication local
configured ?
