How to upgrade System Bootstrap (Cisco 3640)?
rtimmons
How do you upgrade Cisco 3640 System Bootstrap? The early deployment
version 11.1(19)AA that is on one of my 3640's does not recognize a new
card. The same card is recognized fine by a newer System Bootstrap on my
other 3600.
I'm hoping this is the issue and not a hardware problem. I have the version
IOS that should work with the card, but Bootstrap does not seem to see it.
Ray
frejac
Not knowing exactly, but it seems that for the 3600-series one cant upgrade ROMMON in any other way than replacing the chip. (All but one anyway - 3631 seems to be sw-upgradeable)
You should be able to order
BOOT-3600= Boot ROM Upgrade for Cisco 3600
for free (I think, since it's listprice is 0 dollar) if you have a valid contract
Would be a good idea to check releasenotes for info regarding your card. Or contact the TAC.
Anyway, are you running the same IOS release in both routers?
