increasing input queue drop
fvramirez
we have three 7200s that are used as LNS. we have observed that input queue is increasing and also the number of throttles. ip cef is enabled for all three routers. is this okay?
FastEthernet0/1 is up, line protocol is up
Hardware is i82543 (Livengood), address is 000b.60df.f406 (bia 000b.60df.f406)
Internet address is 202.57.124.84/27
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 26/255, rxload 25/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:05:13
Input queue: 6/75/376/18316 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 10015000 bits/sec, 4209 packets/sec
5 minute output rate 10404000 bits/sec, 4412 packets/sec
16524825 packets input, 628602083 bytes
Received 0 broadcasts, 0 runts, 0 giants, 351 throttles
0 watchdog
17319386 packets output, 810962401 bytes, 0 underruns
0 lost carrier, 0 no carrier
deilert
Level 6
Level 6
A throttle happens when the Tx on device connected to this interface is sending traffic faster that the Rx on this device faster than it can handle so the interface sends a message to the processor to throttle back. You can try to increase the size of the inout queue by using the ' hold-queue xx in ' command or you can investigate the connected device to try to determine what is causing this interface to be overrun with traffic.
A lot of the time this is caused by bursty traffic i.e. broadcasts being sent ever 30 seconds for example IPX SAPs.
Is this IP only over this interface ,
