IOS router 2600 problem
csco11571701
IP_ADDRESS: 10.10.10.1
> IP_SUBNET_MASK: 255.255.255.0
> DEFAULT_GATEWAY: 10.10.10.10
> TFTP_SERVER: 10.10.10.10
> TFTP_FILE: c2600-js-mz.122-15.T16.bin
> ARP: ADDRESS RESOLUTION  for 10.10.10.10 timed out
> ARP failed with failure code 1. TFTP transfer aborted.
note: i connected cross cable between router and my pc and i put image of router in tftp_file with tftp server so when the router wants confirm y or n and i make y so my connection area connect and disconnect and never make connection with router so how can i slove it please and give me the steps in my pc and the router i used solarwinds tftp server ...
David Aicher
The problem is that ARP fails.  Make sure that the cable is plugged into the ethernet 0 port as the 2600 expects this to be the interface used for tftpdnld.  Also make sure that your PC is statically configured with the ip address of 10.10.10.10.   You may need to hard code speed and duplex on you PC as well to make this work.
Dave
yes sir i maked all things before but not work but when i make it in packet tracer
prog its work from first try but in real not work so do you know about any more steps for
recovery image?? or slove this problem??
Well failing arp means that either the interface did not come up or the attached device did not respond.  There is very limited
troubleshooting ability for this as the router only expects the interface to work and there is nothing we can get as an
output to verify.  You could try something like wireshark to see if the interface is receiving the arp request.
Otherwise if you don't have any image on the device the only other solution is xmodem
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080094a0b.shtml
Dave
