09-07-2004 10:09 AM - edited 03-02-2019 06:17 PM
When I use this command I notice that the call ends after 120 seconds. Is this the default time limit on this command? Is there other commands to lengthen the test call?
Thanks.
Solved! Go to Solution.
09-07-2004 01:03 PM
the 120 seconds are directly related to the default dialer idle-timeout, which is that 120 seconds. Change the dialer idle-timeout to e.g. 180 seconds, and the call will be connected for that period of time.
Georg
09-07-2004 01:02 PM
ISDN interfaces have "dialer in-band" enabled by default so your connections will time out after 120 seconds. You can change this by putting in the command "dialer idle-timeout x" where x is the time in seconds.
Apply this command to the ISDN B or D channel interface.
You should do this on both sides of the connection.
Daniel
09-07-2004 01:03 PM
Georg
09-10-2004 06:50 AM
Thank you.
