ISDN wrong: debug isdn q921, help me!
lihuaiyu543200
i have configured isdn calling router. with ping to the destination address and using debug isdn q921, it always display:
*Mar 1 19:41:41.763: ISDN BR0: TX -> RRp sapi = 0 tei = 65 nr = 0
*Mar 1 19:41:41.831: ISDN BR0: RX <- RRf sapi = 0 tei = 65 nr = 0
following is detail:
guangzhou# show isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 65, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Activated dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
guangzhou#show debug
ISDN:
ISDN events debugging is on
ISDN Q921 packets debugging is on
ISDN Q931 packets debugging is on
ISDN events debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
1 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
ISDN Q921 packets debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
ISDN Q931 packets debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 31
guangzhou#ter mon
guangzhou#show terminal
Line 6, Location: "", Type: "ANSI"
Length: 26 lines, Width: 80 columns
Baud rate (TX/RX) is 9600/9600
Status: PSI Enabled, Ready, Active, No Exit Banner
Capabilities: Receives Logging Output
Modem state: Ready
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
never never none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is unknown.
Session limit is not set.
Time since activation: 00:00:30
Editing is enabled.
History is enabled, history size is 10.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed transports are pad telnet rlogin. Preferred is telnet.
No output characters are padded
--More--
*Mar 1 19:41:21.615: ISDN BR0: TX -> RRp sapi = 0 tei = 65 nr = 0
*Mar 1 19:41:21.687: ISDN BR0: RX <- RRf sapi = 0 tei = 65 nr = 0
*Mar 1 19:41:31.687: ISDN BR0: TX -> RRp sapi = 0 tei = 65 nr = 0
*Mar 1 19:41:31.763: ISDN BR0: RX <- RRf sapi = 0 tei = 65 nr = 0
*Mar 1 19:41:51.831: ISDN BR0: TX -> RRp sapi = 0 tei = 65 nr = 0
*Mar 1 19:41:51.903: ISDN BR0: RX <- RRf sapi = 0
not sure if the posted configuration for your router 'guangzhou' is complete, but I do not see a dialer-list statement, so there is no interesting traffic defined to trigger the call. Try and add the following to the configuration of your router 'guangzhou':
guangzhou(config)#dialer-list 1 protocol ip permit
HTH,
GP
12 Replies 12
it could be an authentication problem. Make sure you have the appropriate usernames configured on both sides. Can you post the configurations of both ends ?
Georg
i have checked the authentication. both routers have related usename and same password.
the calling router configuration:
guangzhou#show run
Building configuration...
Current configuration:
version 12.0
service password-encryption
hostname guangzhou
enable secret xxxxx
enable password xxxxx
username canhs password xxxxx
username bj3662 password xxxxxx
memory-size iomem 20
ip subnet-zero
isdn switch-type basic-net3
interface Serial0
ip address 192.168.248.2 255.255.255.0
no ip directed-broadcast
priority-group 1
interface Serial1
no ip address
encapsulation frame-relay
load-interval 30
priority-group 1
frame-relay lmi-type ansi
interface Serial1.1 point-to-point
ip address 192.168.201.26 255.255.255.252
ip ospf network broadcast
ip ospf priority 0
frame-relay interface-dlci 114
interface BRI0
bandwidth 64
ip address 192.168.181.7 255.255.255.240
encapsulation ppp
ip ospf demand-circuit
load-interval 30
dialer idle-timeout 60
dialer string 01064639224
dialer hold-queue 75
dialer load-threshold 5 either
dialer-group 1
ppp authentication chap
interface FastEthernet0
ip address 192.168.75.254 255.255.255.0
half-duplex
interface Async5
ip address 192.168.78.225 255.255.255.252
encapsulation ppp
dialer in-band
dialer idle-timeout 300
async mode dedicated
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.201.25
ip route 0.0.0.0 0.0.0.0 192.168.181.1 210
ip route 192.168.78.0 255.255.255.252 Async5
no ip http server
access-list 100 permit ip host 0.0.0.0 host 192.168.10.3
access-list 100 permit ip host 0.0.0.0 host 192.168.10.4
access-list 100 permit ip host 0.0.0.0 host 192.168.10.13
access-list 100 permit ip host 0.0.0.0 host 192.168.10.16
priority-list 1 protocol ip high list 100
priority-list 1 protocol ip normal tcp 1352
priority-list 1 protocol ip normal tcp smtp
priority-list 1 protocol ip normal tcp pop3
priority-list 1 default high
snmp-server engineID local xxxxx
snmp-server community public RO
line con 0
session-timeout 5
exec-timeout 0 30
password xxxxx
login
transport input none
line aux 0
modem InOut
transport input all
stopbits 1
speed 38400
flowcontrol hardware
line vty 0 4
exec-timeout 0 0
password xxxxxx
login
end
the called router configuration:
username guangzhou password xxxxx
interface BRI1/0
bandwidth 64
ip address 192.168.181.1 255.255.255.240
encapsulation ppp
no ip mroute-cache
load-interval 30
dialer idle-timeout 180
dialer-group 1
ppp callback accept
HTH,
GP
thank you very much!
after adding the configuration it is ok.
now i can ping successfully from `guangzhou` to `beijing`, but (i use floating route in 'guangzhou') if i shut down the interface on the `beijing` of the line between `beijing` and `guangzhou`, why i can not ping successfully from `beijing` to `guangzhou`.
thanks a lot!
can you post the configuration of your 'bejing' router as well ? Do you have the ISDN link configured as a backup link with the 'backup interface' command on the serial interface ? If that is the case, keep in mind that administratively shut interfaces are not seen as link failures by ISDN backup interfaces.
GP
Current configuration : 25259 bytes
version 12.3
service timestamps debug uptime
service timestamps log datetime localtime
service tcp-small-servers
hostname BJ3662
boot-start-marker
boot system flash flash:c3660-i-mz.123-7.t.bin
boot system flash flash:c3660-i-mz.122-8.T.bin
boot-end-marker
logging buffered 8192 debugging
enable secret xxxxx
clock timezone gmt 8
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
controller E1 2/0
framing NO-CRC4
channel-group 0 timeslots 1-31 speed 64
description CHINA TELECOM 1
interface Loopback0
ip address 192.168.180.1 255.255.255.0
ip ospf network point-to-point
interface Loopback2
ip address 192.168.254.1 255.255.255.0
interface FastEthernet0/0
no ip address
load-interval 30
speed 10
full-duplex
interface FastEthernet0/1
ip address 192.168.10.254 255.255.255.0
ip accounting access-violations
load-interval 30
speed 10
full-duplex
interface BRI1/0
bandwidth 64
encapsulation ppp
no ip mroute-cache
load-interval 30
dialer-group 1
ppp callback accept
interface BRI1/1
ip unnumbered Loopback0
encapsulation ppp
no ip mroute-cache
dialer idle-timeout 600
dialer wait-for-carrier-time 15
dialer load-threshold 1 either
dialer-group 1
interface Serial2/0:0
description China Telecom 30N0001 2M fr
no ip address
load-interval 30
interface Serial2/0:0.1 point-to-point
description Changsha 64K/64K
ip address 192.168.205.1 255.255.255.252
ip ospf priority 10
frame-relay interface-dlci 501
interface Serial2/1:0
bandwidth 2048
no ip address
load-interval 30
interface Async225
ip address 192.168.15.1 255.255.255.0
encapsulation ppp
dialer in-band
async default routing
async dynamic routing
no peer default ip address
keepalive 10 3
router ospf 100
log-adjacency-changes
area 9 virtual-link 192.168.243.2
redistribute connected
redistribute static
network 192.168.8.0 0.0.0.255 area 0
network 192.168.10.0 0.0.0.255 area 0
network 192.168.15.0 0.0.0.255 area 9
network 192.168.92.0 0.0.0.255 area 3
network 192.168.156.0 0.0.0.255 area 10
network 192.168.244.0 0.0.0.255 area 6
network 192.168.249.0 0.0.0.255 area 0
default-information originate always
ip http server
ip classless
no ip forward-protocol udp bootps
ip route 0.0.0.0 0.0.0.0 192.168.10.5
ip route 10.0.7.184 255.255.255.252 192.168.201.6
ip route 192.168.75.0 255.255.255.0 192.168.181.7 210
retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-mes
ge
snmp-server enable traps ipmulticast
control-plane
line con 0
exec-timeout 0 0
password xxxx
login
transport preferred all
transport output all
line aux 0
modem InOut
modem autoconfigure discovery
transport input all
stopbits 1
speed 115200
line vty 0 4
exec-timeout 20 0
password xxxx
login
transport input all
end
hello
i have posted the configuration of `beijing`.
i don't use `backup interface` on the serial interface. i use floating route to start up the backup line on the `guangzhou`.
from what I can see, your 'beijing' router also does not have the dialer-list statement, so a connection can only be established from the 'guangzhou' router. Try and add the statement:
beijing(config)#dialer-list 1 protocol ip permit
This should enable the 'beijing' router to start a connection to 'guangzhou'.
HTH,
GP
sorry. because the configuation is so big that i don't post this configuration on.
i am sure the router has dialer-list statement.
ok, assuming the dialer-list statement is on there, can you post the output of:
debug dialer events
from the 'beijing' router while you are trying to ping the other side ?
GP
hello,
before i ping the other side, is it necessary to shutdown the interface linking to the other side?
thanks.
if you work with floating static default routes with different administrative distances, you indeed need to shut down the primary interface, in order for the secondary default route to become active.
Georg
