ISE indexing engine not running
I have two ise 2.3 servers and in order to create ha.
after ha two ise server, The following problem happened
serivce ISE Indexing Engine not running.
please help me
Ben Walters
Level 4
Level 4
Have you seen this thread?
https://communities.cisco.com/thread/86829
Sounds like a reverse DNS record for your ISE nodes is required for the service to properly start in HA setups.
Hi Dear
I Checked reverse DNS records for ISE nodes.
Reverse DNS are already created But the problem did not resolve
same issue....
dns records are persist/ Certificates installed, time zone, NTP correct....
tried restart...no luck(
ise/admin# ping ise
PING ise (10.0.64.228) 56(84) bytes of data.
64 bytes from 10.0.64.228: icmp_seq=1 ttl=64 time=0.028 ms
64 bytes from 10.0.64.228: icmp_seq=2 ttl=64 time=0.028 ms
64 bytes from 10.0.64.228: icmp_seq=3 ttl=64 time=0.020 ms
64 bytes from 10.0.64.228: icmp_seq=4 ttl=64 time=0.039 ms
--- ise ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3001ms
rtt min/avg/max/mdev = 0.020/0.028/0.039/0.009 ms
ise/admin# sh clock
Mon Jun 17 14:39:34 MSK 2019
ise/admin#
ise/admin# sh ntp
Configured NTP Servers:
10.0.64.1
10.101.0.136
10.101.0.137
synchronised to NTP server (10.101.0.137) at stratum 3
time correct to within 474 ms
polling server every 64 s
remote refid st t when poll reach delay offset jitter
127.127.1.0 .LOCL. 10 l 87 64 76 0.000 0.000 0.000
+10.0.64.1 89.109.251.21 2 u 13 64 77 2.341 -3.561 0.318
+10.101.0.136 194.190.168.1 2 u 12 64 77 0.555 -0.015 0.635
*10.101.0.137 89.175.20.7 2 u 14 64 77 0.581 -2.561 0.628
