09-10-2015 07:28 PM - edited 03-03-2019 07:59 AM
This day found there is an issue between the our 2 LDP Neighbors Switches.LDP neighbor router id is continues flapping for few secs. There is some TCP Sync problem the you can see as following.
P2#sh tcp brief all
TCB Local Address Foreign Address (state)
55B7A194 10.13.130.4.32702 10.13.130.2.179 SYNSENT
53D7D134 0.0.0.0.179 10.13.130.2.* LISTEN
Here your can see neighbor router id is missing.
P2#sh mpls ldp discovery
Local LDP Identifier:
10.13.130.4:0
Discovery Sources:
Interfaces:
TenGigabitEthernet2/7 (ldp): xmit
TenGigabitEthernet7/8 (ldp): xmit/recv
LDP Id: 10.13.130.3:0
Here you can see route id come back.
10.13.130.4:0
Discovery Sources:
Interfaces:
TenGigabitEthernet2/7 (ldp): xmit/recv
LDP Id: 10.13.130.2:0
Following is the detail of Neighbor discovery.
P2#sh mpls ldp discovery Detail
10.13.130.4:0
Discovery Sources:
Interfaces:
Enabled: Interface config
Hello interval: 5000 ms; Transport IP addr: 10.13.130.4
Clients: IPv4, mLDP
Src IP addr: 10.13.131.17; Transport IP addr: 10.13.130.3
Hold time: 15 sec; Proposed local/peer: 15/15 sec
Reachable via 10.13.130.3/32
Password: not required, none, in use
Clients: IPv4, mLDP
The is no problem in route as route exist in the routing table.
OSPF is running and route also exist in the routing table.
P2#sh ip route ospf
Gateway of last resort is not set
1.0.0.0/24 is subnetted, 1 subnets
O 1.1.1.0 [110/11] via 10.13.131.13, 05:27:20, TenGigabitEthernet9/7
10.0.0.0/8 is variably subnetted, 28 subnets, 3 masks
O 10.13.130.1/32
[110/2] via 10.13.131.13, 05:27:20, TenGigabitEthernet9/7
O 10.13.130.2/32
[110/2] via 10.13.131.29, 05:27:16, TenGigabitEthernet2/7
Details of LDP Parameters are as following.
P2#sh mpls ldp parameters
LDP Feature Set Manager: State Initialized
LDP features:
Basic
IP-over-MPLS
TDP
IGP-Sync
Protocol version: 1
Session hold time: 180 sec; keep alive interval: 60 sec
Discovery hello: holdtime: 15 sec; interval: 5 sec
Discovery targeted hello: holdtime: 90 sec; interval: 10 sec
Accepting targeted hellos
Downstream on Demand max hop count: 255
LDP for targeted sessions
LDP initial/maximum backoff: 15/120 sec
LDP loop detection: off
T1-SOC-Co2#sh mpls ldp parameters
Protocol version: 1
Can someone help to troubleshoot the issue. What can be the reason?
Solved! Go to Solution.
09-11-2015 04:46 AM
You should not ask in random communities unrelated to the topic of question. If you wish for valuable response ...
I moved it to Other Network Infrastructure Subjects to increase your chances. Unfortunately, you disclosed no product you are speaking of nor the firmware version so I'm unsure it will help so much.
09-11-2015 04:46 AM
09-11-2015 10:55 AM
Glad to hear my comment has solved the issue, although I'm surprised a lot ...
09-15-2015 12:13 PM
Thanks for it, We are using 6500 on both switches. For P1 we using IOS ADVIPSERVICESK9_WAN-M Version 12.2(33)SXH5 and for P2 using ADVENTERPRISEK9-M), Version 15.1(2)SY4a.
