I'm trying to understand in a VoIP situation over a WAN link whether you'd use LFI with FRF.12 or limit the frame size using MTU? The link is over frame relay. Anyone any thoughts?
LFI with FRF.12 might be a better choice, as lowering the MTU will increase the header overhead by extra 20 bytes for every IP fragment, whereas the overhead due to LFI may not be that much.
Learn, share, save
