Lightstream ASP error:M4:Non-Volatile Memory Read/Write Test []
dinglerj
I have this error on A Cisco LightStream ASP card.:
*** MEMDIAG_NVRAM_MAGIC_PATTERN_DATA_ERROR *** [Addr:BE001008, exp:0000ABCD, act:00000000]
Can you tell me which memory is bad and can it be fixed ??
The diag power-on passes self tests but shows this error. Will it cause loss of packets ??
umedryk
Level 5
Level 5
This could be some sort of the NVRAM corruption, and in order to solve the problem the NVRAM needs to be erased, the LS be reloaded ;that should clean it up; If the problem persists, this could mean a Hardware issue with the NVRAM
