LOAD BALANCING IN EQUAL COST PATH FOR EIGRP
ngopinath
We are using EIGRP & we have 4 64kbps links to our HO.But load balancing is not taking place.
I have also enabled ip load-sharing per-packet still load balancing is not happening.
Any command for load balancing for equal cost path for EIGRP.....
Pls help me out...
Regds,
Gopi
Richard Burts
There are several pieces of information that would be helpful in attempting to help solve your question. If there are 4 equal cost paths in EIGRP then there should be some load sharing taking place. Please post the output of show ip eigrp interface and also the output of show ip route. It would also be helpful if you post the config of the 4 interfaces and the configuration of EIGRP.
Rick
Rick
