11-06-2007 06:36 AM - edited 03-03-2019 05:41 AM
Hi all, I'm having this problem and I cannot find any bug or TAC case in the collection. I'm using PAT between two ethernet interfaces on a c3745 or c3845(I tried both in a lab).
If I keep the duplex and speed negociation to auto, everything works fine and it autonegotiates to full/100, but as soon as I force the duplex to full and speed to 100, the transfer rate of my FTP drops considerably. When I change the speed back to auto everything goes back to normal. I've tried the latest IOS but the problem persist.
Anyone experienced the same problem? Any ideas?
Thanks in advance,
Mariano
Solved! Go to Solution.
11-06-2007 06:46 AM
Fixing speed and duplex must be done on both sides. If one end remains in auto-mode the connection will default to half duplex.
This will result in a duplex mismatch between the devices.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1904.htm
regards,
Leo
11-06-2007 06:46 AM
regards,
Leo
11-06-2007 07:16 AM
Thank you for your answer. I was confused because both sides reported a full/100 negotiation, but forcing caused the problem.
I guess I'll stay in the safe side by forcing everything. Anyway, thanks again.
