06-19-2005 11:24 PM - edited 03-02-2019 11:09 PM
Hi to All
I m preparing for BSCI 642-801 exam these days , and studying Cisco press book by Clare Gough
The problem iss
The book says that Five types of packets are used to build the routing tablefor the first time
1.Hello
2.Database Descriptor
3.Link State Request
4.Link State Update
5.Link State Ack
My question is "Where is LSA-Link State Advertisement"
Is it DAtabase Descriptor And Link State Update
or something else
Thanks in advance for ur answer
Syed Umair Ali
Solved! Go to Solution.
06-20-2005 12:00 AM
Hello Syed,
basically, LSA advertisement means simply that LSA packets (which can contain the five packet types you have mentioned) are being sent periodically between OSPF neighbors in order to keep the topology table updated and consistent throughout the OSPF domain.
Does that make sense ? Check the following documents which might clarify the concept:
What is OSPF ? (Scroll down to the ' Packet Format' section
http://www.pulsewan.com/data101/ospf_basics.htm
OSPF Neighbor States
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0e.shtml
GP
06-20-2005 12:00 AM
Hello Syed,
GP
06-20-2005 02:41 AM
Hi all,
I am new to this Netpro. Iam not any professional.
My answer may be wrong. If so please correct me.
There are five types of OSPF packets.
1. Hello - Finds the neighbor & goes into 2way.
In case of Pt-to-Pt Networks it tries to become adjacent with it's neighbor with the help of DD Packets.
2. DD packets - It chooses a Master/Slave during Exstart state. During Exchange state exchanges "LSA headers" which are available in their database.
Both the routers prepare Requestlist(The list of LSAs which are latest/or not availbale in its database)
3. LS Request - LSA headers in the requestlist are sent to the neighboring router (to get the complete LSAs). The state is "Loading". Loading and Exchange can be parallel process reduce the convergence time.
4. LS Update - Requested updates are sent with the help of these pkts. These "LSAs" are stored in the OSPF Database.Now this router makes the state of other "FULL" SPF will be run locally to prepare the IP Forwarding table (Routing Table)
5. LS Ack pkt - Either implicit or explicit Acks are sent.
Now Mr. Syed I am going to answer your question.
1.During Exchange state a router exchanges "LSA headers" that are stored in it's OSPF Database.
2. OSPF Database is filled up when the router receives LS update pkt.
3.From the above argument I presume that "Link State Advertisement" means "Link State Update".
Others like
Hello pkt.- finds the neighbor,
DD pkt.- synchronise the database,
LS req. Pkt - asking for the LSA
LS Ack pkt. for acknowledging the receipt of LSA
are only helping the OSPF process to get the Updates.
Thanks & Regards
Krishnamurthy Suresh
06-20-2005 09:53 PM
Thanks GP(Sorry I dont know ur full name) and Suresh for ur help. Now I got the answer. specially GP ur 2nd Link is the best.
Thanks Again
