Management VLAN not passing traffic
scbbni
Question:
Does anybody know why a VLAN would stop passing traffic? Additionally, why would the arp cache entry of a network device (on that same VLAN) that has changed IP addresses still show up in the arp cache two days after it was changed?
Summary:
I have a Cisco 7500 series router with a RSP2 processor running a 12.2(29) IOS image.
On Saturday the Gig card in slot 6/0/0 went bad after a suspect power outage. The switches were moved over to the Gig card in slot6/0/0 started passing traffic. At the same time the management VLAN assigned to the Gig card in slot 5/0/0 stopped passing traffic. However, every user VLAN/subinterface assigned to 5/0/0 is up, but we’ve had sporadic complaints from customers having intermittent printing, IPTV (multicasting), email and connectivity issues. All issues were resolved before we could look at them.
- The “show VLAN” command indicates the router is not receiving traffic on VLAN 600.
- 5/0/0.600 (IP: 132.60.251.1) is up/up and I can ping the subinterface IP address.
- The “show CDP neighbor detail” command shows the Catalyst 4912 directly connected
to interface 5/0/0.
- VTP information is correct and the 4912 is trunking and passing the other 14 user VLANs traversing it.
- The “show arp” command shows every switch IP address but the mac is incomplete.
- Loaded a new IOS image in the router and rebooted.
- Changed the management IP address and VLAN on the 4912 and I could connect to it remotely.
- Reseated the card in slot 5/0/0 and rebooted the switch . . . no change in status. The strange part is that the old IP address of the Catalyst 4912 will not flush out of the arp cache. It’s been over a day since I changed the IP address, upgraded the IOS image and have rebooted the switch.
- The log file shows nothing.
Config:
interface GigabitEthernet5/0/0.600
encapsulation dot1Q 600
ip address 132.60.250.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip security extended-ignored
ntp broadcast
Solution:
??? Suspect the router hardware is bad. Especially after the power hit on Saturday night, but can’t prove it as most everything is running behind the router except the management VLAN.
scbbni
Catalyst 4912 went bad after power hit. Replaced the device and eveything is working fine.
