MLS QOS problems on 3750
rob.maynard
When i enable mls qos on 3750 running EMI image the ingress ports should switch to non-trusted and therefore reclassify all DSCP/COS bits to 0.
This is not happening and the COS bits are reamining as set by the IP handsets and pc's.
This does not happen on 3550 or 6500's which i have just tested to verify.
umedryk
Level 5
Level 5
What is the exact version of OS you are using ?
