MTRACE problem
irelandsky
Hi all,
i've some problem with my multicast flow.
If i use mtrace command from side A to side B all is Ok, but when i do mtrace from B to A i see this output
Source address or name: 10.10.50.8
Destination address or name: 192.168.65.100
Group address or name: 231.31.31.31
Multicast request TTL [64]:
Response address for mtrace:
Mtrace from 10.10.50.8 to 192.168.65.100 via group 231.31.31.31
From source (?) to destination (?)
Querying full reverse path...
0 192.168.65.100
-1 0.0.0.0 None [default]
-2 0.0.0.0 None [default]
-3 0.0.0.0 None [default]
-4 0.0.0.0 None [default]
-5 0.0.0.0 None [default]
-6 0.0.0.0 None [default]
-7 0.0.0.0 None [default]
-8 0.0.0.0 None [default]
-9 0.0.0.0 None [default]
-10 0.0.0.0 None [default]
-11 0.0.0.0 None [default]
-12 0.0.0.0 None [default]
-13 0.0.0.0 None [default]
-14 0.0.0.0 None [default]
-15 0.0.0.0 None [default]
-16 0.0.0.0 None [default]
-17 0.0.0.0 None [default]
-18 0.0.0.0 None [default]
-19 0.0.0.0 None [default]
-20 0.0.0.0 None [default]
-21 0.0.0.0 None [default]
-22 0.0.0.0 None [default]
-23 0.0.0.0 None [default]
-24 0.0.0.0 None [default]
-25 0.0.0.0 None [default]
-26 0.0.0.0 None [default]
-27 0.0.0.0 None [default]
-28 0.0.0.0 None [default]
-29 0.0.0.0 None [default]
-30 0.0.0.0 None [default]
-31 0.0.0.0 None [default]
-32 0.0.0.0 None [default]
-33 0.0.0.0 None [default]
-34 0.0.0.0 None [default]
-35 0.0.0.0 None [default]
-36 0.0.0.0 None [default]
-37 0.0.0.0 None [default]
-38 0.0.0.0 None [default]
-39 0.0.0.0 None [default]
-40 0.0.0.0 None [default]
-41 0.0.0.0 None [default]
-42 0.0.0.0 None [default]
-43 0.0.0.0 None [default]
-44 0.0.0.0 None [default]
-45 0.0.0.0 None [default]
-46 0.0.0.0 None [default]
-47 10.10.50.8
What does 0.0.0.0 None line mean ???
Thanks all
Marco
ebreniz
Level 6
Level 6
