06-28-2005 01:26 AM - edited 03-02-2019 11:13 PM
Does anybody have some usefull links or information regarding CEF/Multi-layer switching? How are these features interacting with each other? Key differences?
Thank's a lot.
Florian
06-28-2005 03:06 AM
Hi Florian,
Basically in MLS the first packet to reach the destination rill need to be processed by router as it just maintain the caches and so for second packet it gets wr writed in hardware.
But in CEF even the first packet is hardware switches as it builds the adjacency table and FIB table. Which not only maintains the routing entried but also the arp entried like binding the mac with ip so that even first packet can be hardware switches.
Have a look at this white paper for CEF
http://www.cisco.com/warp/public/cc/pd/iosw/iore/tech/cef_wp.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/mls.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/cef.htm#
Ankur
06-28-2005 04:23 AM
Florian,
Here is another useful document to add to the ones Ankur gave you:
http://www.cisco.com/en/US/tech/tk827/tk831/technologies_tech_note09186a0080094b27.shtml
Hope it helps.
Kevin Dorrell
Luxembourg
