We are running dynamic NAT and ZBF on cisco router but guest wifi users always have connection issues, i mean they can connect to wifi but unable to access internet and every time i have to clear NAT translations so the internet gets connected, following day same will occur and i have to clear translations again. Can anyone suggest if you encountered this issue ? Suspecting NAT or ZBF timers sync issue but quite not sure as we are not using any parameter map or nat timers which i believe are using default as they are not configured with custom values and any light on this is appreciated.
