NAT Problem
mhixservice
I trying to configure NAT on a 1711 Security router. My outside interface is fastethernet0 address 68.238.170.27, and my inside interface is VLAN1 address 10.10.10.1. I am able to ping a public addres from the router, but I cannot access the internet from a dynamic address assign by the router.
Below is the startup-config on the router. Please be kind enough to help me find a solution to this problem.
Many thanks.
Building configuration...
Current configuration : 2608 bytes
! Last configuration change at 16:19:27 America Tue May 18 2004
! NVRAM config last updated at 16:09:37 America Tue May 18 2004
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router1
security authentication failure rate 3 log
security passwords min-length 6
logging queue-limit 100
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$XR57$13nL3UQDF6C70eZCiZRZU0
username xxxxx privilege 15 password 7 051F0E0A2B4D430C0A50
clock timezone America/New_York -5
clock summer-time America/New_York date Apr 6 2003 2:00 Oct 26 2003 2:00
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip domain name yourdomain.com
ip name-server xxx.202.0.8
ip name-server xxx.203.0.8
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
no ip bootp server
ip cef
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface FastEthernet0
description $ETH-WAN$
ip address xx.xxx.170.27 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
no ip address
no cdp enable
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface Vlan1
description $FW_INSIDE$$ETH-SW-LAUNCH$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip classless
ip route 0.0.0.0 0.0.0.0 xx.xxx.170.1
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
no cdp run
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line 1
flush-at-activation
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
scheduler interval 500
end
rais
Level 7
Level 7
You need to add NAT command such as:
ip nat inside source list 10 interface fastethernet0 overload
access-list 10 permit 10.10.10.0 0.0.0.255
Hope this helps.
Thanks.
Thank You!!!!
The addition of these new commands worked perfectly.
Thanks again Rais
