08-21-2018 03:19 AM - edited 03-03-2019 08:53 AM
Hello ,
Is there a nexus switch of 24 ports where the ports are SFP based (1 gig /10Gig/40Gig). I need a mix of copper(RJ45) and Fiber ports.
Then to populate the switch , I just need to buy the correct SFP(copper RJ45 or Fiber).
Can you please advise on a model.
I’ve seen fiber nexus switches , but it’s a bit confusing.
Solved! Go to Solution.
08-22-2018 04:40 AM
I haven't actually used these platforms but it looks like a good fit too. I checked and it should work with copper gig SFPs too. Your original post said a 24 port switch, but if you are good with the 48, then it should fit the bill.
08-21-2018 12:13 PM
I haven't used them, but it looks like the Nexus 3524 comes close to what you want. It supports 1/10G and 1G in both fiber and copper. It will also do 40G, but requires using 4 sequential 10G interfaces with a special transceiver.
Below is a link that provides the info as well as the compatible SFPs.
Hope this helps.
08-21-2018 09:46 PM
08-22-2018 04:40 AM
08-22-2018 04:46 AM
