OSPF Load Balancing
karief
Can anybody tell me for How many P-to-P (E1's) can load balance at a time in OSPF as Routing Protocol.
regards
arief
The limit was 6 until the release of IOS 12.3.2T. Starting with this release of IOS the limit is 16. See the following url:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/
Cheers
Regards, LG
*** Please Rate All Helpful Responses ***
Hi..
Iam having Flex Wan Module(8port)embedded in 6509 (MSFC's) Having version of 12.1(8a)es in site A and Site B is connected with (2) 7513's , Totally Iam having 8 E1's connected (4 in one 7513 and another 4 in 2nd 7513).But Iam getting only 4 links been load balanced. If I want to have all the 8 to be balanaced.What is the solution and which rtelease can support this...
regards
arief
You can use the "maximum-paths x" under the router command mode to adjust the number of maximum parallel paths, which is 4 by default, but can be up to 6.
Hope I helped
Hi..
Thanks , yes it helped , now i configured for 8 and it works fine...
regards
arief
