Packet mode versus character mode
wim_depauw
can somebody tell me what the difference is between these auth modes ? When do I need which mode and how do I need to configure this ?
rrijk
Wim,
Here is an URL.
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00800945cc.shtml
In character mode, you are usually securing the router itself. In packet mode your are allowing users to connect to network services.
regards,
RdR
I found some more information:
What is the difference between character mode and packet mode?
Character mode sends keystrokes to the router through the TTY, vty, AUX, and CON ports
for configuration or query commands. Packet mode uses interface mode or a link protocol
session to communicate with a device other than the router. These defined interfaces
would be the async, group-async, BRI, PRI, serial, dialer profiles, and dialer rotaries.
http://www.unix.org.ua/cisco/CCNP-CCDP/RemoteAccess-CP2001/ra-466.html
regards,
RdR
