Possible to configure Policy routing on tunnel interface?
MARK BAKER
Level 4
Level 4
Is it possible to configure policy based routing on a tunnel interface, specifically mGRE tunnel interfaces supporting wireless layer three roaming.
Thank you,
Mark
wong34539
Level 6
Level 6
You can try to add the route-map and make it match an access list where all the traffic that should be incoming by vlan-x and need to go over the tunnel is specifid.
route-map tunnel_Name permit 10
match ip address 110
set ip next-hop
access-list 110 permit ip.......
Thanks for the reply.
I am actually asking about policy routing traffic inbound on the tunnel interface.
interface tunnel0
ip policy route-map tunnel0
route-map tunnel0 permit 10
set int gi9/7
If anyone knows if this is possible, I would appreciate your reply.
Thank you,
Mark
