problem mapping drive over VPN - W2k
aoshea
Dear Support,
Was wondering if anyone could give me some advice, or tell me it is a windows issue.
Have setup a vpn between two sites to add bandwidth rather than the expenses of upgrading the FR.
I am able to ping, tftp, web browse across the vpn, but if i try to map a drive by name it fails. I can however map via IP address. The mapping by name works on the FR.
Thanks in advance.... think it is a windows thing?
regards. Adrian
paddyxdoyle
Level 6
Level 6
How are you allocating addressing information to your clients?
Have you configured a WINS server IP address to be allocated to your clients from your VPN device?
run "ipconfig /all" on your windows client to check for a WINS server.
There is a useful link here all about such issues, i think its more than likely a WINS problem as you can't map or ping by name!
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a0080194b4a.shtml
Good Luck
Paddy
