Problem of pinging from pc to server
ljywm19
I wonder why one of my pc can't ping to the server ( when press simulation there is a red checkmark) either the studentPc or teacherPC can work only.
If studentPC can ping the server, then teacherPC will get a red checkmark.
There is a link for my packet tracer. Thanks a lot to whoever can help!
not really sure what your topology is supposed to do. The server at the top does not do any routing, so each side will never be able to reach the other side. Can you explain what the server is supposed to do ?
Hello
As the server cannot perform the routing function, you just need to apply it to the staff-rtr and add a couple of stack routes
Please review working PT file.
Kind Regards
Paul
