Problem show buffers 2950
pgarrido
Hi:
I have a problem with show buffers 2950, what recommend you to me to do? I made clear counters but the values followed equal.
thank's
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(13)EA1c, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 24-Jun-03 17:31 by yenanh
Image text-base: 0x80010000, data-base: 0x805A8000
ROM: Bootstrap program is CALHOUN boot loader
BBN_41 uptime is 9 weeks, 6 days, 8 hours, 33 minutes
System image file is "flash:c2950-i6q4l2-mz.121-13.EA1c.bin"
cisco WS-C2950G-24-EI (RC32300) processor (revision G0) with 20839K bytes of memory.
the show buffers:
------------------ show buffers ------------------
Buffer elements:
489 in free list (500 max allowed)
192390541 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 31, permanent 25, peak 49 @ 7w0d):
27 in free list (20 min, 60 max allowed)
84084385 hits, 1042 misses, 2031 trims, 2037 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 30, permanent 15, peak 39 @ 7w0d):
16 in free list (10 min, 30 max allowed)
3422374 hits, 632 misses, 1118 trims, 1133 created
Big buffers, 1524 bytes (total 10, permanent 5, peak 62 @ 1w6d):
10 in free list (5 min, 10 max allowed)
3459162 hits, 788140 misses, 381587 trims, 381592 created
428970 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 0, peak 22 @ 5w2d):
10 in free list (0 min, 10 max allowed)
5917114 hits, 145818 misses, 18122 trims, 18132 created
145752 failures (0 no memory)
Large buffers, 5024 bytes (total 2, permanent 0, peak 11 @ 1w6d):
2 in free list (0 min, 5 max allowed)
70088 hits, 75686 misses, 10365 trims, 10367 created
75680 failures (0 no memory)
Huge buffers, 18024 bytes (total 2, permanent 0, peak 7 @ 1w6d):
2 in free list (0 min, 2 max allowed)
17441 hits, 58248 misses, 7876 trims, 7878 created
58243 failures (0 no memory)
Prashanth Krishnappa
Buffer counters are cleared only on a reload. if you are seeing them increment, check for any broadcast/multicast storms/unicast flooding
the buffer counters won´t be reset unless you reboot the switch.
Are you experiencing performance problems ? If so, and if possible, try to upgrade to IOS version 12.1(22).
HTH,
Georg
I am not experiencing performance problems but the exit the outputinterpreter see Error
is there a bug? relation.
thank's
