Problem with ACLs/ wildcard masks
clare.wood
We are attempting to configure an ACL on a 2600 series router.
The network that we wish to permit access from is x.x.x.128 (255.255.255.128).
In the extended ACL we are using the following syntax
access-list 101 permit ip x.x.x.128 0.0.0.128 any
The router accepts this, but when you subsequently do a show access-list 101, it shows the following
access-list 101 permit ip x.x.x.0 0.0.0.128 any
which relates to a totally different subnet (which in this case is the destination network).
This seems to happen unless 0 or 255 is used in the wildcard mask.
Has anyone encountered this/ any suggestions? is this just a display issue on the show command?
unless this is a type, your access-list syntax does not appear to be right:
needs to read:
access-list 101 permit ip x.x.x.128 0.0.0.127 any
in order to allow network x.x.x.128. An easy rule to calculate the wildcard mask is to subtract the network (128 in this case) from 255, which in this case equals 127.
HTH,
GP
