Problem with MST
per.nielsen
I have enabled MST on a access layer switch
here is the MST config
spanning-tree mode mst
spanning-tree portfast bpduguard default
no spanning-tree optimize bpdu transmission
spanning-tree mst configuration
name building1
revision 1
instance 2 vlan 12
instance 6 vlan 16
Now look at this output fro show sho span tree
How come the switch thinks it's the root switch for MST02 & MST06 and at the same time be blocking ports
ASW12#show spanning-tree
MST00
Spanning tree enabled protocol mstp
Root ID Priority 32768
Address 000a.f49a.b080
Cost 200000
Port 1 (FastEthernet0/1)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32768 (priority 32768 sys-id-ext 0)
Address 0013.8038.5fc0
Interface Role Sts Cost Prio.Nbr Type
Fa0/1 Root FWD 200000 128.1 P2p Bound(RSTP)
Fa0/2 Altn BLK 200000 128.2 P2p Bound(RSTP)
Fa0/3 Desg FWD 2000000 128.3 Edge Shr
MST02
Root ID Priority 32770
This bridge is the root
Bridge ID Priority 32770 (priority 32768 sys-id-ext 2)
Fa0/1 Boun FWD 200000 128.1 P2p Bound(RSTP)
Fa0/2 Boun BLK 200000 128.2 P2p Bound(RSTP)
MST06
Root ID Priority 32774
Bridge ID Priority 32774 (priority 32768 sys-id-ext 6)
Also I have an upstream switch with this mst config
spanning-tree vlan 1,12-13 priority 8192
name building1
revision 1
instance 1 vlan 11
instance 2 vlan 12
instance 3 vlan 13
instance 5 vlan 15
instance 6 vlan 16
instance 7 vlan 17
spanning-tree mst 1,3,6 priority 8192
spanning-tree mst 2,5,7 priority 4096
We cant even control which which port becomes the root port on out acces layer switch
In fact is doing the total opposite that we have requested
cheers
smahbub
Level 6
Level 6
Multiple Spanning Tree (MST) is an IEEE standard inspired from the Cisco proprietary Multiple Instances Spanning Tree Protocol (MISTP) implementation. This document assumes that the reader is familiar with Rapid STP (RSTP) (802.1w), as MST heavily relies on this other IEEE standard.
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_white_paper09186a0080094cfc.shtml#invalid_configuration
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800951ac.shtml
Francois Tallet
Level 7
Level 7
You need to have a little bit more understanding of what MST is, which is not obvious for engineers very used to PVST.
In MST, there is a dependency between instances: basically, all MST Instances (id > 0) depend on the CIST (id 0). MST Instances have a scope restricted to an MST region, ie, a group of switch sharing the exact same MST configuration. At the boundary of a region, all MST Instances follow the state of the CIST.
In your example, the port you mention is at the boundary of the switch's region (its neighbor is not in the same region). As a result, all the MST Instances follow the state of the CIST for this port: as F0/2 is blocking for instance 0, it will be blocking for all the instances.
The bridge is root for the MST Instances, because it has the best root ID for these instances in the region (again, the instances only exist within the region).
Francois
